AndroGen
Oct 13, 2019Guide
WAC720 - no possiblity to login after the firmware update (V3.9.1.0)
Hi,
After the firmware upgrade from V3.9.0.3 to V3.9.1.0 I cannot login to the WAC via WEB interface.
If I type wrong password - system complains that the password is no correctm; with correct password - it simply does not leave the logon screen.
Browser cach reset did not help.
I can connect to the WAC via SSH,
I have tried to reset password as it is mentioned in this post - password command does not exist:
https://community.netgear.com/t5/Business-Wireless/WAC510-Cannot-login-after-latest-firmware-update-8-2-1-16/m-p/1802693#M6838
Both updated WACs behave identically.
Could you please help me to resole this issue?
Thanks,
Andre
Welcome to the community! :)
Kindly try this command: set system password <NewPassword> then save it.
Note: Be reminded that the special characters that are allowed for the admin password are the following: !@#$%^&*()
If ever your concern has been addressed or resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
DaneA
NETGEAR Community Team
The WAC720 is similar to the WAC730 (less to the WAC5xx). While the source issues is the same - ridiculous change of the allowed characters for a password in the Web UI, the process to fix is different and might require the assistance from RaghuHR. Sorry, how can such a major design change hit the production world?
- AndroGenGuide
thanks, I have realized that there is something different between WAC5xx and my WAC720.
At least your reply gives me a hope that it might be fixed.
Yes, few special characters have been used, and it was fine before the upgrade.
Then question: how I can reset password without resseting the entire system, that there is no breackage in operation - likely there are 2 WAC720 connected in the ansemble mode, and theoretically could be managed separately.- schumakuGuru - Experienced User
Login using SSH (permitting it's enabled) and run the command shown, setting a new password on each device. This should not have any impact on the ensemble mode, and does not require a reset.
- DaneANETGEAR Employee Retired
DaneA
