RSH_nomad's avatar
Nov 09, 2017
WAC720 not registered
Hi all,
I encounter a problem with one of my WAC720. I use business central to control my wireless network and my 3 WAC720.
To isolate my production, guest and byod networks, I set different VLAN for the different SSID.
The voucher portal doesn't work if there is no WAC720 in the guest LAN so I put one in the network. Since then, it doesn't appear as registered in the business central view (in the top right corner in the configuration page). The other two works fine and apply VLAN correctly. They are also mark as registered.
All SSID provides by the one in the guest network provides access to the guest LAN.
The all three WAC720 has the same access to internet.
I don't know what to do to see my WAC registered in BC and i don't know if it will resolve my problem.
Anyone could help?
Thanks in advance,
Maxime
  • RaghuHR's avatar
    RaghuHR
    Nov 15, 2017
    Hi Maxime,
    We have an entry for this SN: 4D7466EB0012D in our database. For now we have deleted so that you can register again. Could you please try again and share your feedback?
    Thanks
    Raghu
  • RaghuHR's avatar
    RaghuHR
    NETGEAR Expert
    We are checking your account internally and update you.
    Thanks
    Raghu
  • RaghuHR's avatar
    RaghuHR
    NETGEAR Expert
    Hi Maxime
    It looks like you have you *may* not have checked the box to 'register' the device when adding into Business Central.  We suggest you to delete and re-add the device, ensure that you have checked the register box.
    Thanks,
    Raghu
  • Hi Raghu,
    Thanks for your help.
    I just tried to re-register the WAC.
    I could delete it without problem and I unconfigured the BC configuration on the WAC.
    When I registered it on the BC, I entered the SN, the name, checked the register and let my purchase date on today. I saved and I saw an error message :
    Unable to register device: Serial number [SN here] already registered
    The WAC was back in my listed devices after that.
    I configured the BC on the WAC and the BC showed me the information about the WAC (MAC address, IP, SN, etc).
    Maybe you can do something on your side.
    Best regards,
    Maxime
    • RaghuHR's avatar
      RaghuHR
      NETGEAR Expert
      Hi Maxime,
      Thanks
      Raghu
  • Hi Raguh,
    This works. I re-registered the WAC and all gone right.
    All my SSID are correctly using their VLAN.
ProSupport for Business
