redtech116
Nov 29, 2016Aspirant
WAC720 WDS not stable
The WDS between two WAC720 will stop working for a minute or two and come back a few times a day the log states [Nov 29 2016 10:29:41] [info] hostapd[6299] STA 2c:30:33:08:a2:c0 deauthed from BSSID...
- Dec 07, 2016
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Nov 30, 2016NETGEAR Employee Retired
Hi redtech116,
As far as I know, there is no issue on the WAC720 like what you have described on your initial post. Kindly answer the questions below:
a. Are the 2 WAC720 within line of sight to each other?
b. What is the distance between the 2 WAC720?
c. How are the 2 WAC720 deployed? Are both mounted on the ceiling or on the side wall?
d. Are there any other wireless networks present within the area where the 2 WAC720 are deployed?
e. What is the current firmware version of the 2 WAC720?
f. Since you have tried to re-setup the 2 WAC720 and still the same problem, have you tried to perform a factory reset on both APs then reconfigure it from scratch then observe if same problem will occur?
DaneA
- redtech116Nov 30, 2016Aspirant
A. no, there are some walls
b. 70ft
c.both seated on a shelf
d. a bunch
e. the most current that is on netgears site 3.6.12.0 i think
f. thats my next step. and moving one AP to an outdoo enclosure and using some external ant.
