redtech116
Nov 30, 2016Aspirant
WAC720 WDS not stable
The WDS between two WAC720 will stop working for a minute or two and come back a few times a day the log states [Nov 29 2016 10:29:41] [info] hostapd[6299] STA 2c:30:33:08:a2:c0 deauthed from BSSID...
- Dec 07, 2016
We’d greatly appreciate hearing your feedback letting us know if the information I’ve provided has helped resolve your concern or if you need further assistance.
If ever your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
RaghuHR
Nov 30, 2016NETGEAR Expert
Hi Glenn
Additional to Dane questions would it be possible to share the following info?
1. Country settings
2. On which radio you are seeing this issue?
3. Are you seeing the issue on both radios?
Thanks
Raghu
redtech116
1. both the same NA-NORTH AMERICA (USA) PACIFIC TIME)
2. the scond ap point
3 no just loosing the ping on the second
- redtech116Nov 30, 2016Aspirant
Just changed the the 2.4ghz channel to 1 from 11 also..see how it fairs today..
am using the 2.4ghz / channel 1 for the WDS between the access points also..
- DaneADec 04, 2016NETGEAR Employee Retired
Hi redtech116,
Just want to follow-up on this. What are your observations when you changed the channel from 01 to 11 within the 2.4GHz band? Also, were you able to perform a factory reset on both APs then reconfigure it from scratch then observe if same problem will occur?
DaneA
- redtech116Dec 07, 2016Aspirant
it's not dropping anymore..still having a few episodes a day where pings will get slow and some packetloss but it returnes to normal in a minute or two..
I am going to be moving it outdoors an enclosure..I think it should solve the issues.
I have not done a full cleanout and re-setup.
- DaneADec 07, 2016NETGEAR Employee Retired
Regards,DaneA
