Peter-G
Jul 28, 2016Aspirant
WAC730 - Accessing user interface after installation
Apologies, but I am a novice when it comes to this, but....
I am trying to set up my WAC730 Access Point within my home network. I have configured the AP through my PC and now want to distribute it...
- Aug 01, 2016
Hi Peter-G,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
JohnRo
Jul 29, 2016NETGEAR Employee Retired
Hello Peter-G,
Welcome to the community!
If you did not assign a static IP address to the access point, what you can do is to access the UI of your router and check its IP address table. You should be able to access the UI of the AP from any of the computers connected to your LAN.
Let us know if this helps.
Thanks,
