Peter-G
Jul 28, 2016Aspirant
WAC730 - Accessing user interface after installation
Apologies, but I am a novice when it comes to this, but....
I am trying to set up my WAC730 Access Point within my home network. I have configured the AP through my PC and now want to distribute it...
- Aug 01, 2016
Hi Peter-G,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
JohnRo
Aug 01, 2016NETGEAR Employee Retired
Hi Peter-G,
Thanks,
Peter-G
Aug 01, 2016Aspirant
Hi
My sincere apologies for the delay in replying, personal commitments (guests visiting!) so I was not able to check this out until now
Yes, excellent it works.
I was able to also check this using Netgear Genie. Now able to access the AP
Thanks very much
- JohnRoAug 01, 2016NETGEAR Employee Retired
Hi Peter-G,
No worries! Just checking if my suggestion had worked or if you have any more questions. :)
Have a great day!
Thanks,
