Rheen-2015
Jun 20, 2024Follower
WAP Setup WAX214v2
I could use some help. I just built a new home. I prewired Cat6 cable for my networking. I just got my internet installed by Xfinity. They hooked up the Netgear modem/router and switch that I purchas...
BrianL
Jun 28, 2024NETGEAR Moderator
Hi Rheen-2015,
schumaku suggestion is correct. The AP has a LAN/POE+ port. Connect the cable to a PoE+ port on a PoE+ (802.3at) switch for normal suggested operation status. If you use a PoE (803.2.af) switch, the AP’s 2.4 GHz radio functions with reduced transmit power.
Kind regards,
BrianL
