ihavealegohead
May 27, 2022Guide
WAX 214 laptop Clients dropping "IEEE 802.11: disassociated" - Solved !!
After investing many hours on this forum and others I found a solution that worked for me
Problem:
Multiple laptops (Dell/HP) disassociated from the WIFI
Hardware:
WAX214 - AX1800 WiFi 6 Dual Band PoE Wireless Access Point
Current Firmware Version:2.1.1.2
Error:
WAX214 daemon.info hostapd: ath1: STA [random mac] IEEE 802.11: disassociated
Resolution attempts --
I tried changing channels. One channel, multiple channels, low, high, nothing worked
Set static IP for the WAP
Used different Authentications
Used no authentication (worked but not practical)
Disabled client limits multicast
Disabled client isolation, vlan isolation, l2 isolation
Disabled Band Steering
Changed the Group Key Update Interval to diff values and disabled
Removed all WAX 214's from the service except the one I was next to
power cycled
^ nothing worked (except no authentication)
I didn't try a Radius server, but there is one on PFSENSE and that was going to be my last step.
Solution --
This was the last thing I tried because it makes no sense whatsoever :
I disabled any Access Point that had BOTH 2.4 GHz and 5GHz.
Note --- If my laptop was connected to Access Point A where only 5GHz was selected, but Access Point B had both selected, the laptop still "disassociated". Both access points can have only one Wireless band selected, even if your laptop is not connected to it.
During testing I also had situations where my Android would not authenticate to the WIFI at all. I tried to enter in the password again but failed. I ended up having the change the WPA3 password to something else and then change it back for the android to connect.
Very buggy software NetGear. You can do better.
Hope this helps you - if so give it a thumbs up, maybe NetGear will notice.
No RepliesBe the first to reply
