donjajo
Dec 18, 2025Aspirant
WAX204 cannot run on UPS
I have a WAX204 which I need to plug into a UPS. It runs okay if the UPS is plugged into AC power. However, whenever the power goes out, the router reboots and gets stuck in a boot loop. The loop hap...
donjajo
Dec 22, 2025Aspirant
Thank you for your response. Yes, I am using the original adapter that came with my order.
If I am using a different adapter, what spec should I look out for?
Dec 22, 2025Guru - Experienced User
donjajo wrote:If I am using a different adapter, what spec should I look out for?
12V, 1.5A AC/DC. Including PAV12V25 in the search string might help if you are looking to purchase one.
Is the switch or router connected to the AP powered up during your testing?
- donjajoDec 22, 2025Aspirant
You mean 12V instead of 2V? The original power adapter is 12V, 1.5A
AP is access point, right? Yes, the router is connected to the AP powered up during the testing.
- StephenBDec 22, 2025Guru - Experienced User
yes, sorry for the confusion...
Good. That eliminates the router as a possible trigger for the problem.
I will have to try another adapter and see, but it seems unlikely for me. What could possibly do better than the original adapter?
