Shinobikazuma
Feb 22, 2023Tutor
WAX214 - Wireless Access Point - Issues with Wifi Adapter
Hello all, I'm turning to this forum as I've been troubleshooting this for about a week to no avail. I recently purchased a WAX214 WAP and installed it without any issues to any devices with built in...
schumaku
Feb 23, 2023Guru - Experienced User
Shinobikazuma wrote:
Here's a snippet of the logs as well when trying to connect:
....Feb 22 13:17:57 WAX214 daemon.info hostapd: ath1: STA dc:e9:94:c9:ca:35 IEEE 802.11: associated (aid 1)
Tells us the wireless association is established.
Double check the wireless adapter is configured as a DHCP client, not a static IP.
- ShinobikazumaFeb 23, 2023Tutor
At this time it is configured as a DHCP client but I believe I will need to test on other devices because using the adapter I cannot connect to any network, whether its the WAP, a hotspot, or other. Therefore I believe my configuration on my computer and how it interacts with the adapter might be the issue. Will be ordering another adapter from a different company to test.
- plemansFeb 23, 2023Guru - Experienced User
Hope the new adapter works well.
