matefits
Dec 30, 2022Aspirant
WAX214 UPNP
Hi everyone,
I can't find the option to disable upnp on the WAX214, GUI/SSH
Do you know how to disable it ?
Firmware: 2.1.1.2
Thanks
Talking about the discovery only? There is no routing so no UPnP PMP, too.
- matefitsAspirant
Hi,
Thanks for you reply,
yes i would like to disable the discovery, i don't use UPNP for security purpose
Thanks
Most implementations of UPnP PMP inherit certain security risks (exposal on LAN or WAN) UPnP device announcements are oversee able. To many people are running crazy if they hear UPnP..
