fattom23
Mar 04, 2024Aspirant
WAX214 VLAN set up Correctly?
I'm trying to set VLANs on my network based on SSID and can't seem to find out where things are going wrong. I have an SSID set on my WAX214 with VLAN Isolation activated and the VLAN ID set to 20. W...
schumaku
Mar 04, 2024Guru - Experienced User
fattom23 wrote:
I don't have the v2, but I should be able to borrow a POE injector to try and plug directly into an access port straight on the router.
What should this test be good for? You want to test a specific SSID mapping into a certain (tagged) VLAN.
Tell us more about the config of your router, and he switches along of the data path.
fattom23
I have a Mikrotik routerboard with Port 2 going to Port 1 on a Zyxel switch (its a GS1900-24). Port 7 on that switch goes to Port 5 on a Netgear switch (it's a Netgear GS308EPP). I use this switch because it's POE (which neither the switch or router are).
The APs (2 WAX214s) are plugged into Ports 3 and 4 of the Netgear switch. Both switches (for testing purposes) have all ports listed as Trunk (tagged) ports for VLAN 20. The SSID LaPortaPile-Test is mapped to VLAN 20 on the AP.
I've attached screenshots of the relevant screens from the AP, and have the config from the router and additional screenshots from the switches if it becomes helpful.
- fattom23Mar 04, 2024Aspirant
This is the router config:
# mar/03/2024 20:26:25 by RouterOS 6.49.11
# software id = DD4H-LACA
# model = RB3011UiAS
# serial number = HFG097R51BQ
/interface bridge
add admin-mac=78:9A:18:D8:75:F2 auto-mac=no comment=defconf name=bridge
/interface ethernet
set [ find default-name=ether9 ] name="ether9(Management)"
/interface vlan
add interface=bridge name=vlan1 vlan-id=20
/interface list
add comment=defconf name=WAN
add comment=defconf name=LAN
/interface wireless security-profiles
set [ find default=yes ] supplicant-identity=MikroTik
/ip pool
add name=default-dhcp ranges=192.168.88.10-192.168.88.254
add name=dhcp_pool1 ranges=98.111.140.2-98.111.140.254
add name=dhcp_pool3 ranges=192.168.1.2-192.168.1.254
add name=dhcp_pool13 ranges=10.0.0.2-10.0.0.254
/ip dhcp-server
add address-pool=dhcp_pool3 disabled=no interface=bridge name=dhcp1
add address-pool=dhcp_pool13 disabled=no interface=vlan1 name=dhcp2
/interface bridge port
add bridge=bridge comment=defconf interface=ether2
add bridge=bridge comment=defconf interface=ether3 pvid=20
add bridge=bridge comment=defconf interface=ether4
add bridge=bridge comment=defconf interface=ether5
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=sfp1
add bridge=bridge interface=ether7
/ip neighbor discovery-settings
set discover-interface-list=LAN
/interface list member
add comment=defconf interface=bridge list=LAN
add comment=defconf interface=ether1 list=WAN
add interface="ether9(Management)" list=LAN
/ip address
add address=192.168.1.1/24 interface=bridge network=192.168.1.0
add address=192.168.100.1/24 interface="ether9(Management)" network=\
192.168.100.0
add address=10.0.0.1/24 interface=vlan1 network=10.0.0.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-client
add comment=defconf disabled=no interface=ether1 use-peer-dns=no
/ip dhcp-server lease
add address=192.168.1.246 mac-address=B8:AB:62:2E:A4:BD server=dhcp1
add address=192.168.1.23 mac-address=DC:E5:5B:5F:EC:94 server=dhcp1
add address=192.168.1.128 mac-address=10:BF:48:8D:AA:A0 server=dhcp1
add address=192.168.1.168 client-id=\
ff:f6:86:2c:2f:0:2:0:0:ab:11:67:e9:d2:38:8f:d2:99:5c mac-address=\
54:80:28:4E:FE:E9 server=dhcp1
add address=192.168.1.214 client-id=1:90:6a:eb:bf:b9:61 mac-address=\
90:6A:EB:BF:B9:61 server=dhcp1
add address=192.168.1.241 client-id=\
ff:eb:7c:56:8d:0:1:0:1:2a:34:d6:82:e8:4e:6:9b:1e:1e mac-address=\
B8:27:EB:7C:56:8D server=dhcp1
add address=192.168.1.109 client-id=1:d8:c0:a6:20:3c:91 mac-address=\
D8:C0:A6:20:3C:91 server=dhcp1
add address=192.168.1.146 client-id=1:c4:3c:b0:62:c5:3 mac-address=\
C4:3C:B0:62:C5:03 server=dhcp1
add address=192.168.1.15 client-id=1:e0:46:ee:14:98:92 mac-address=\
E0:46:EE:14:98:92 server=dhcp1
add address=192.168.1.47 client-id=1:d8:ec:e5:d3:bb:5e mac-address=\
D8:EC:E5:D3:BB:5E server=dhcp1
add address=192.168.1.51 mac-address=80:CC:9C:48:D8:20 server=dhcp1
add address=192.168.1.52 mac-address=80:CC:9C:48:FF:29 server=dhcp1
add address=192.168.1.31 client-id=1:8:bf:b8:b8:e:d9 mac-address=\
08:BF:B8:B8:0E:D9 server=dhcp1
/ip dhcp-server network
add address=10.0.0.0/24 gateway=10.0.0.1
add address=10.10.10.0/24 gateway=10.10.10.1
add address=98.111.140.0/24 dns-server=192.168.1.1,129.168.1.1 gateway=\
98.111.140.1
add address=172.16.0.0/24 gateway=172.16.0.1
add address=172.16.1.0/24 gateway=172.16.1.1
add address=192.168.0.0/24 gateway=192.168.0.1
add address=192.168.1.0/24 dns-server=192.168.1.1,129.168.1.1 gateway=\
192.168.1.1
add address=192.168.88.0/24 comment=defconf dns-server=192.168.88.1 gateway=\
192.168.88.1
/ip dns
set allow-remote-requests=yes servers=1.1.1.1,9.9.9.9
/ip dns static
add address=192.168.88.1 comment=defconf name=router.lan
/ip firewall address-list
add address=hfg097r51bq.sn.mynetname.net list=WAN-IP
/ip firewall filter
add action=accept chain=input comment=\
"defconf: accept established,related,untracked" connection-state=\
add action=drop chain=input src-address=112.227.133.59
add action=drop chain=input comment="defconf: drop invalid" connection-state=\
invalid
add action=accept chain=input comment="defconf: accept ICMP" protocol=icmp
"defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=drop chain=input comment="defconf: drop all not coming from LAN" \
in-interface-list=!LAN
add action=accept chain=forward comment="defconf: accept in ipsec policy" \
ipsec-policy=in,ipsec
add action=accept chain=forward comment="defconf: accept out ipsec policy" \
ipsec-policy=out,ipsec
add action=fasttrack-connection chain=forward comment="defconf: fasttrack" \
connection-state=established,related
add action=accept chain=forward comment=\
"defconf: accept established,related, untracked" connection-state=\
add action=drop chain=forward comment="defconf: drop invalid" \
connection-state=invalid
add action=drop chain=forward comment=\
"defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat \
connection-state=new in-interface-list=WAN
/ip firewall nat
add action=masquerade chain=srcnat comment="Hairpin NAT - Not Working" \
dst-address=192.168.1.0/24 src-address=192.168.1.0/24
add action=masquerade chain=srcnat comment="defconf: masquerade" \
ipsec-policy=out,none out-interface=ether1 out-interface-list=WAN
add action=dst-nat chain=dstnat dst-address-list=WAN-IP dst-port=32400 \
protocol=tcp to-addresses=192.168.1.168
add action=dst-nat chain=dstnat dst-address-list=WAN-IP dst-port=80 protocol=\
add action=dst-nat chain=dstnat dst-address-list=WAN-IP dst-port=443 \
add action=dst-nat chain=dstnat comment="Needed for Xbox" dst-port=53 \
in-interface=ether1 protocol=tcp to-addresses=192.168.1.214 to-ports=53
add action=dst-nat chain=dstnat dst-port=3074 in-interface=ether1 protocol=\
add action=dst-nat chain=dstnat dst-port=88 in-interface=ether1 protocol=udp \
to-addresses=192.168.1.214 to-ports=88
udp to-addresses=192.168.1.214 to-ports=3074
add action=dst-nat chain=dstnat dst-port=500 in-interface=ether1 protocol=udp \
to-addresses=192.168.1.214 to-ports=500
add action=dst-nat chain=dstnat dst-port=3544 in-interface=ether1 protocol=\
udp to-addresses=192.168.1.214 to-ports=3544
add action=dst-nat chain=dstnat dst-port=4500 in-interface=ether1 protocol=\
udp to-addresses=192.168.1.214 to-ports=4500
add action=dst-nat chain=dstnat dst-port=53 in-interface=ether1 protocol=udp \
add action=dst-nat chain=dstnat dst-address-list=WAN-IP dst-port=80 \
in-interface=ether1 protocol=tcp to-addresses=192.168.1.1 to-ports=80
/ip service
set telnet disabled=yes
set ssh address=192.168.1.0/24
/system clock
set time-zone-name=America/New_York
/system package update
set channel=upgrade
/tool mac-server
set allowed-interface-list=LAN
/tool mac-server mac-winbox
set allowed-interface-list=LAN- schumakuMar 05, 2024Guru - Experienced User
Great, and that VLAN 20 is trunked (tagged) throughout the ZyXEL switch on the data path (switch ports) connecting the router and the Netgear Plus switch?
- fattom23Mar 05, 2024AspirantIt seems to be (see attached screenshot). I obviously went wild trunking the ports and don't need all this, but I figured I should reduce the chance of misconfiguration for now.
