fattom23
Mar 04, 2024Aspirant
WAX214 VLAN set up Correctly?
I'm trying to set VLANs on my network based on SSID and can't seem to find out where things are going wrong. I have an SSID set on my WAX214 with VLAN Isolation activated and the VLAN ID set to 20. W...
schumaku
Mar 04, 2024Guru - Experienced User
Great, and that VLAN 20 is trunked (tagged) throughout the ZyXEL switch on the data path (switch ports) connecting the router and the Netgear Plus switch?
fattom23
Mar 05, 2024Aspirant
Now that I'm looking at it, the ports in question (2 and 7) are Tagged for VLAN 20 and Untagged for VLAN 1 on the Zyxel (which seems like not the correct configuration). I'll bet the problem is with the configuration of the Zyxel, because those should be Tagged for both in order for it to work, correct?
- schumakuMar 05, 2024Guru - Experienced User
fattom23 wrote:
Now that I'm looking at it, the ports in question (2 and 7) are Tagged for VLAN 20 and Untagged for VLAN 1 on the Zyxel (which seems like not the correct configuration). I'll bet the problem is with the configuration of the Zyxel, because those should be Tagged for both in order for it to work, correct?In case 2 and 7 making up the trunk connections, sure, 7 needs to be tagged, too. Unfortunately, the ports are not labeled on the switch, so hard to say what is connected there. So best guess Yes 8-)
