prosyn
Sep 19, 2024Aspirant
WAX214v2 use POE instead of POE+
Hi, We have a WAX214v2 access point connected to a Cisco C1000-48P-4X-L switch using POE+, both use POE+ (802.at 25.5 W) but access point indicate "PoE/AF Input power detected. Use POE+ or AT Swi...
Nivedita
Sep 19, 2024NETGEAR Expert
Hi,
Thank you for reaching us.
How many PoE+ devices are connected to Cisco switch?, need to check whether the AP requested power and switch is able to deliver the requested power. Could you please try using different ethernet cable and changing the switch port?.
The log of the switch shows that the device is connected to AT, but the AP actually receives AF input.
When the AF input AP is fully loaded, the power consumption is insufficient.
Can AP be turned on normally when the switch is powered by AT mode? or is there some services running after the AP is powered on normally, causing the switch to stop power supply?.
Because, we use PoE+ switch in our lab and didn't come across power negotiation issue.
