prosyn
Sep 19, 2024Aspirant
WAX214v2 use POE instead of POE+
Hi, We have a WAX214v2 access point connected to a Cisco C1000-48P-4X-L switch using POE+, both use POE+ (802.at 25.5 W) but access point indicate "PoE/AF Input power detected. Use POE+ or AT Swi...
prosyn
Sep 20, 2024Aspirant
Hi,
Thanks for the reply.
Only one device use POE on the switch, this is the access point. The total power of the switch is 370W, we can see on the switch that 802.3at is used by the AP. We already tried to use another cable on another port, same result.
The POE+ negotiation seems to be OK. We received email when configuration changed, and at startup, we received three emails :
- firmware check
- [Configuration Changed]-powerdetection.power.power_recv_pseAllocated='13000'
- [Configuration Changed]-powerdetection.power.power_recv_pseAllocated='25500'
Regards.
Nivedita
Sep 20, 2024NETGEAR Expert
Hi,
Thank you!.
I replied you via private message, could you please share AP logs there.
Thanks,
Nivedita
