RN7
Mar 10, 2023Aspirant
Wax610 5ghz not working on certain devices. Specially on my S22 ultra.
MY 5ghz is not working in my s22 ultra. it works with other routers with 5ghz. on the other hand my iphones work perfectly with my AP's 5ghz. how to solve the issue?
Do other devices see the WAX's 5ghz?
Just not the S22?Hello,
Can you please share few more details
1) SSID Security configurations : WAP2-PSK or WPA3-PSK or WPA2/WPA3 Mixed mode ?
2) Is 802.11w (PMF) enabled or optional ?
3) what is radio mode set ?
or you you send just us the techsupport log file and enable diagnostic (SD . It will help us.
- RN7Aspirant
2) Is 802.11w (PMF): Disabled
3) what is radio mode set?: 11ax
- RN7Aspirant
Yes. Other devices see AP's 5Ghz. for example, my laptop, iphone 14 pro max.
