JonB16's avatar
JonB16
WAX610 slow blinking amber after firmware update to 9.5.1.20
After upgrading to 9.5.1.20, the WAX610 stayed with a slow blinking amber light (I have never seen the fast blinking mentioned in the user guide for updating firmware) so I am assuming slow. In any c...
  • DaneA's avatar
    DaneA
    Sep 08, 2021
    JonB16
    Kindly try to update the firmware of your WAX610 to the latest version which is v9.5.3.2.  You can download it here.  Then, check if the same problem will occur.
    DaneA
    NETGEAR Community Team
ProSupport for Business
