jukste
Aug 06, 2024Aspirant
WAX610 upgrade to 10.8.6.6 firmware version issues
 Hi all, I upgraded two WAX610 to the latest version at the same time (bad yes). Instantly I noticed different issues :   some SSID were not broadcasted anymore  radio signal was weaker in some areas ...
jukste
Aug 18, 2024Aspirant
Hi Pramendra, sorry for my late reply. I will send you logs asap. I did the upgrade again of only one access point.
Kr
ErwinL
Jan 08, 2025NETGEAR Moderator
Hello jukste
And welcome to the NETGEAR Community! 🙂
If you are certain that you have a stable network with the prvious firmware I suggest you really have to roll back it to previous firmware. It may prolong your dilema if you are sure that the latest firmware really has issues. But if this is not the case you could also try checking your switch where your APs are connected. What brand of switch are your access points connected?
Have a lovely day,
Erwin
Netgear Team
