Dinsdale87
Feb 04, 2023Guide
WAX620 - clients dropping and rejoining constantly - can't connect with iOS
Hello Hope to get some help, as I'm at the end of my tether. My WAX620 hasn't been working properly for over a month and seems to be getting worse. It's got to the point now where I genuinely fee...
michaelkenward
Feb 04, 2023Guru - Experienced User
The WAX620 isn't one of the Nighthawk with WiFi 6 (AX) and WiFi 6E (AXE) Routers covered in this section of the community. It is a fancy Wireless Access Point.
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Business Wireless - NETGEAR Communities
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
I have a DOCSIS 3.1 Virgin Hub 5, and that has a Netgear GS308EPP with PoE, and the WAX62P is powered by said PoE.
I'd be in the lookout for interactions between what looks to me like a slightly complicated network.
All alien territory to me, but for a start, I'd want to know how the Virgin Hub 5 is configured.
Dinsdale87
Feb 04, 2023Guide
Thanks. Since my message I've since went through a ridiculously user unfriendly process to reset and remove again, this time getting it to local mode and removing it from Insight.
As for your note, I had 4 options to choose from and this was the closest. When I click "Show all", it gave me a tree full of empty options. I am really stressed with Netgear. Every time you go to get help, there's another issue blocking you from getting the help.
EDIT: When I posted this, I got "Your post has been changed because invalid HTML was found in the message body. The invalid HTML has been removed. Please review the message and submit the message when you are satisfied." I mean, unbelievable!
Anyway, it now looks like the SSID I want to use and have used forever now can't be used, but any other SSID, it works fine. This is ridiculous - even after resetting both the AP and the client device. It just hangs and hangs, so I've downloaded the logs and seeing stuff like
amazon-xxxxx (xx-xx-xx-xx-xx-xx) wireless client could not obtain IP address
So, why can it obtain IP address when I use a different cosmetic SSID.
I'll post on the forum as you suggest, but what a load of rubbish this AP is.
- matt7277Feb 05, 2023Guide
I had similar issues with the WAX630E APs and finally had to take them offline. Very similar issues (devices disconnecting, deauthing, issues w/ 2.4/5ghz, etc). It wasn't worth the constant issues, so I dusted off some old equipment and I'm no longer dealing with the nonsense.
- jeffdlee95Jul 04, 2023Aspirant
I am a glutton for punishment but I thought the web literature was fancy and went ahead and bought a ton of WAX630 and it basically has been torture for me for 5 days straight. There is this gap in the product universe from soho and 100% mesh systems that don't work well in large spaces, vs. the "enterprise grade" stuff. I guess this is a bad segment in the middle.
- schumakuFeb 06, 2023Guru - Experienced User
The AP isn't in charge for issuing IP addresses. Hard to imagine what is different beyond of the unknown workable and unworkable SSID. Lot of text, but not much other community members like me can hook on.
Lot of text, but not much details other community members like me can hook on. Operating small, mid and bigger environments on these APs....
The industry standard SaaS Netgear is making use for the community forum here, just like virtually hundreds of well known brands and businesses, not accepting any html in the postings. It can happen easily by paste whatever text the users capture from other posts, from other parts of the site, by accident from any device Web UI or from a cloud application. HTML will be stripped on post. Impossible to figure out what happened or what was posted from your Web browser.
- michaelkenwardFeb 06, 2023Guru - Experienced User
schumaku wrote:The industry standard SaaS Netgear is making use for the community forum here, just like virtually hundreds of well known brands and businesses, not accepting any html in the postings. It can happen easily by paste whatever text the users capture from other posts, from other parts of the site, by accident from any device Web UI or from a cloud application. HTML will be stripped on post.
Sadly, Netgear's implementation of this community software is almost guaranteed to introduce html errors into posts.
It happens to me pretty well daily. It occurs when you quote a message from someone and then pick up a second quote.
The resulting code contains a broken "tag" that the community software tries to remove. In the process it breaks the whole message.
Maybe that is what Dinsdale87 sees.
I am now familiar with this bug. When I see it, I reload the saved text and then go into the HTML editor to remove the erroneous tag.
This is so repeatable that I could almost write a macro to correct the community's mistakes.
michaelkenward Probably true, double quoting might be a valid reason. It's however easy to handle if done in time, long before troubles are calling, rarely have to call the hardcore html edit. Yes, careless quoting can be cumbersome.
The point is i can't look into the heads or on the screens of the users. Sometimes some screenshots would be much more useful than rants on the product, on the community system. Appears people are living on a light fuse 8-)
