churchtech3089
Sep 28, 2022Aspirant
WAX630 Firmware issue 10.2.0.16
My network just updated it's firmware from 9.x to the new 10.2.0.16 and I have been having many issues with devices no longer connecting/staying connected or being able to access the internet through the WIFI. Nothing else in the system has changed other than the firmware . Range has been decreased, speed tests also sometimes don't work now as well.
I did not enable any of the new features and confirmed the Power Saver is off through Insight.
I seemed to have some partial success by turning off, and back on the individual SSIDs. This is happening to multiple VLAN s and SSIDs coming through these WAPs.
Is there a way to roll back the FIrmware using the Cloud Portal or do I need to reflash each individual unit to the older firmware. Was working fine prior to the firmware update...
Will rolling back disable my Insight Cloud Portal?
- DaneANETGEAR Employee Retired
Welcome to the community! 🙂
I don't think there is an option to roll back the firmware via Insight Cloud Portal or Insight App.
What specific wireless devices are having issues staying connected or no longer connecting or being able to access the internet through the WIFI? Are these iOS devices, Android devices, MAC PC, Windows PC, etc? Please indicate their OS versions.
Is the wireless security set to WPA3 Enterprise?
DaneA
NETGEAR Community Team- churchtech3089Aspirant
Hi,
Unfortunately it seems to be affecting most things, device wise. Newer, older, Apple, Android, and Windows based. We are running on WPA2 as the WPA2/WPA3 freaked out connecting devices and many just outright didn't work with WPA3. Ah older mobile and computing devices. Thing is, everything was working great until the latest firmware update happened and I started getting calls for help the next morning. (Scheduler did the update overnight...).
