jeffdlee95
Jul 03, 2023Aspirant
WAX630E frequent disconnection
I have 7 WAX630E in a network connected to a GC752XP managed switch. This is behind a firewall device that provides the DHCP, and it connects to my WAN connection (a local fiber broadband company).
Two of the devices disconnect regularly, like every 15 or 30 min. They stay disconnected and are unresponsive, and the clients connected to the APs during this period are not functioning.
Check the Monitoring -> Logs for the time window in question.
Post the last 30 minutes ir the like if you can't figure out.
Consider to Download the Detailed Logs, and post to a cloud system. File a support request and add a link to the support request.
- jeffdlee95Aspirant
Thank you, I downloaded the log file (it was emailed to me).
I am going crazy here with insight showing the WAPs intermittently down, for no reason. All of them at the same time. I started from scratch with the most basic setup so I really don't know what is going on.
When I write to Netgear support, it is a little frustrating when they ask for the log files when obviously I cannot do that when the particular WAP is down. Do I have to power cycle and then in that moment when it is up again, go into the insight app and download the log file?
Appears you try to fight two different problems. Compare quotes above my friend.
Should any device become unresponsive, there isn't much information available following a restart.
For these rare cases - manufacturer independent issues commonly - I'm operating a syslog server and review the logs from there.
