JCC83's avatar
JCC83
WC7500 and remote WAC720 issues
Ok, these are getting annoying.  Site #2 had public IP change so had to rebuild VPN tunnel no big deal just changed the IP on HQ side to their new IP and tunnel was back up and the WAC720 rejoined th...
  • JCC83's avatar
    Oct 10, 2018
    This one falls on the firewall.  Some odd bug where updating one tunnel caused the other tunnel to have issues.  I changed a few things on the tunnel, and then changed them back.  That fixed it even config ended up identical to what it was.  I wont call out the specific vendor, but 3 vendors in play Fortinet, Cisco, and Meraki.  To be fair all 3 are old devices as well from each vendor none are currently being marketed, but only 1 is actually past end of support date.
ProSupport for Business
