leofezollari
Jan 04, 2018Guide
WC7500 LATEST FIRMWARE 6.5.3.2 and wac720 & wnd930
Hi guys I have a wc7500 with firmware 6.0.1.0 , i want to upgrade to latest version 6.5.3.2. But before to go to 6.5.3.2 the article say to go to 6.0.1R.0 . But i am not able to find this version 6.0...
- Jan 07, 2018
Hi leofezollari,
Welcome to the community! :)
Download firmware v6.5.3.2 here, it is a .zip file. You will need to unzip it then you will find the firmware v6.0.1R.0.
Since your 6 WAC720 and 1 WND930 access points are managed by the WC7500, the WC7500 itself automatically upgrades the firmware of the access points connected to it.
If ever you are using a network management software (such as NMS300) which monitors the WC7500, then you will need to use the MIB for the WC7500.
DaneA
NETGEAR Community Team
leofezollari
Jan 05, 2018Guide
UPDATE Please !!!
DaneA
Jan 07, 2018NETGEAR Employee Retired
Hi leofezollari,
DaneA
- leofezollariJan 07, 2018Guide
Hi DaneA
Thanks for your help.
After i upgrade to 6.5.3.2 two of wac720 are in status : Firmware upgrade in progress > Ap is rebooting than gain the same status : Firmware upgrade in progress > Ap is rebooting .
What is have to do in this case ?
THen are not coming in status Connected like the others APs.
br
LEO
2 are on status MAJOR
Total AlarmsDevice Up Down Critical Major
Access Points 5 0 0 2 Clients 0 NA NA NA
- DaneAJan 07, 2018NETGEAR Employee Retired
Kindly try the fix that was done by the forum user on this forum thread (marked as the Accepted Solution). Observe then let us know the result.
DaneA
Hi DaneA
I don't understand where i have to apply these configurations :
"The problem seems to be fixed by adding option vendor 43 and having the vendor ID and IP in hexadecimal format so hopefully all is well."
I have access on Control panel of WC7500 controller .
Leo
Kindly read pages 156-160 of the WC7500 user manual here about Access Point Discovery Guidelines.
If ever the suggestion does not help, I advise you to open a chat or online case with NETGEAR Support at anytime and the NETGEAR Support Team will provide you the steps and assist you in doing the AP recovery procedure.
DaneA
