jptferreira's avatar
jptferreira
WC7520 and WNDAP360 problem with one AP after IP changed
After upgraded to the latest firmware (2.5.0.45) on the WC7520, all the AP's received the upgrade and worked fine, however I had one AP that had an incorrect static ip assigned to it by the previous ...
  • jptferreira's avatar
    jptferreira
    Feb 26, 2018
    After following all the steps nothing worked. Then connected using putty and noticed that the ip address assigned wasn't the default. It assigned a dhcp ip address after reset. I thought it would assign the default ip address as in the manual and so I couldn't connect to it. After that I connected and reconfigured. Thanks!
ProSupport for Business
