SJHCVA
Apr 19, 2016Guide
WC7520 Captive Portal EULA Text Issue on Internet Explorer
G'day! We've just been setting up the Capitive Portal on our NETGEAR WC7520 wireless controller. For some reason the EULA section doesn't display properly on Windows devices when they join ou...
- Oct 04, 2016
Hi JohnRo
Wow, you are ON IT my friend! :smileyvery-happy:
We were indeed sent the latest firmware, after stating in writing that we wouldn't duplicate or otherwise distribute it outside of our organisation etc. :smileyhappy:
They said that because there were only a couple of changes in it they wouldn't be releasing it to the general public via the website, but the changes would eventually have come out in a later firmware version.
I was able to apply the firmware to our wireless controller this morning, and so far all the devices that have connected to the guest Wi-Fi have been presented with the EULA and the text has wrapped correctly etc. We've tried on a Mac laptop, Windows laptop, Windows Phone, iPhone and a basic Android device. So I think that's us sorted n regards to this issue now :smileyhappy:
Thanks for your help :smileyhappy:
Kind regards
Dan
SJHCVA
Apr 19, 2016Guide
To hopefully help illustrate, here's a screenshot of the EULA viewed from a Surface 3 on Windows 10.
There are supposed to be 3 paragraphs of text, but as you can see, the wrapping isn't working so you get 3 sentances you can't read and no way to scroll.
- JohnRoApr 26, 2016NETGEAR Employee Retired
Hello SJHCVA,
Please contact our Support Team regarding this as it looks an issue to me, it might need intervention from the engineering team. It appears that you have already isolated it properly.
Let us know if you have more questions.
Thanks,
- SJHCVAJun 07, 2016Guide
Just to keep this updated...
NETGEAR engineers have re-created this issue in the lab and have now developed some new firmware. It's currently in the beta stage but should be available in a final release within a few weeks :smileyhappy:
- JohnRoJun 07, 2016NETGEAR Employee Retired
Hi SJHCVA,
Thanks for the update! I'm sure this will help a lot of users who is experiencing the same issue.
Cheers,
