las21tech
Jan 12, 2017Aspirant
WC7520 Rebooting Itself
Hi Everyone, Beginning this week, I have had an issue where our WC7520 randomly reboots itself (not the APs, the controller). We're on firmware version 2.5.0.42. The controller just reboots itsel...
- Jan 12, 2017
So it looks like this is due to an issue with firmware version 2.5.0.42, as it has been pulled and 2.5.0.43 is in its place.
I found a very similar situation on the community after my initial posting > WC7520 reboot Issue after AP's ip change.
las21tech
Durga
Jan 12, 2017NETGEAR Expert
Hi,
Please use the latest web release 2.5.0.43, https://www.netgear.com/support/product/WC7520.aspx?cid=wmt_netgear_organic#Firmware Version 2.5.0.43. We fixed the issue in this firmware. Please let us know your feedback after using it.
- LaxmankumarGJan 22, 2017NETGEAR Expert
Hi,
Did you get a chance to upgrade WC7520 firmware to the latest 2.5.0.43?.
- las21techJan 23, 2017Aspirant
Yes, I installed the update.
I noticed that I had an AP unplugged from power one day, plugged it back in and the system did not reboot as it did on the prior firmware version installed. Everything seems to be working as expected.
- DaneAJan 23, 2017NETGEAR Employee Retired
Thanks for the update! :) We're glad to know that updating to the latest firmware v2.5.0.43 has helped.
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
