BishopTinsly
Jul 01, 2016Aspirant
WC9500 not sending info to RADIUS server
I have a WC9500, set up for WPA2 with RADIUS, i have the correct profile and RADIUS sever set up, i can ping the WC from the RADIUS and vis versa. however when i go to auth to the RADIUS server nothing happens, and there is no log incident created on the RADIUS server. I have used a nother program to ping the RADIUS server with bad login information and log incident is created. Any advice or something im missing.
It was a defective WC, a new one needed to be sent out to resolve.
- DaneANETGEAR Employee Retired
Hi BishopTinsly,
Kindly answer the questions below:
a. Was this working fine before?
b. What is the current firmware version of the WC9500?
DaneA
NETGEAR Community Team
- BishopTinslyAspirant
It has only been set up in the way that it is now, and the WC is running Firmware version: 5.5.1.0.
I updated the the WC to the latest frimware V5.5.1.4, did not resolve the issue
- thchengNETGEAR Expert
Hi,
Have you had the chance to reference the user manual for WC9500? The document is retrieavable from the below link:
http://www.downloads.netgear.com/files/GDC/WC9500/WC9500_UM_3Jan2106.pdf?cid=wmt_netgear_organic
the setup for Radius page is reference on page 143.
Select Configuration > Security > Advanced > Authentication Server
Thanks,
Thomas
