wspall's avatar
wspall
Tutor
Jan 18, 2017
WGAP950 - GUI login
I have pulled out a pair of WGAP950 outdoor access points that been in storage for a number of years!
Can't find any doco on Netgear's website or elsewhere and having reset both units, cannot find a login (username/password) combination to gain access to the device GUI.
Does anyone have any idea on what this might be...? Have tried all combinations from standard netgear documentation..
thanks in advance
WS..
  • Hi Wayne (@wspal)
    What browser are you using to open the GUI?
    would you able to use old IE like IE8/9 to open the GUI and try the login credential (admin/password) again?
    Jonathan
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi wspall,
    Welcome to the community! :)
    I have searched online about the WGAP950 as well through our resources and I cannot find any information about this access point.  If I look through the NETGEAR EOL (End-of-Life) Bulletin here, there is no WGAP950 as well.  Is the WGAP950 a NETGEAR device?  It would be best to post an image of it showing that its a NETGEAR access point.
    DaneA
    NETGEAR Community Team
    • wspall's avatar
      wspall
      Tutor
      Hi DaneA
      Thanks for this, trust me this has not been an easy endeavour hence my asking the community... the only website I found which lists this unit with many other “Netgear” devices, is this one... http://www.downloads.netgear.com/files/answer_media/2649_GPL.html
      The included image, showing front and back, has the “Netgear Prosafe” logo and model number emblazoned on the front. So too does all the boxing, unfortunately no manuals though !!
      Thanks again for your assistance on this intriguing situation !!
      Regards
      Wayne..
      • DaneA's avatar
        DaneA
        wspall,
        I have inquired your concern to a higher tier of NETGEAR Support.  The WGAP950 might be possibly only available on some countries or region.  The default credentials I have found out are the following below:
        username: admin
        password: password
        default IP address: 192.168.0.229
        Note: The default username and password are all in lowercase letters.
        DaneA
ProSupport for Business
