JoeBishopCDS
Aug 26, 2015Aspirant
WMS5316 Access Point Groups
Hello, We are trying to configure a Guest Network on our WNDAP350 APs using a WMS5316, i can see how to do this (in theory create a new profile with the correct vlan etc.) but unfortunately when ...
- Sep 08, 2015
Hi JoeBishopCDS,
The only way to achieve this is to use another AP that will be linked to a new profile that will only broadcast the staff SSID with MAC restriction.
Just let me know if you have other questions.
Kind regards,
BrianL
NETGEAR Community
JoeBishopCDS
Aug 27, 2015Aspirant
Hi Brian,
Ah, i thought this may of been the case!
We want to lock down our staff only SSID network by mac restriction, unfortunately when we do this our guest network SSID is also locked down as its in the same profile group as the staff one. I then had the idea to create a new profile group, and add the APs to this hoping that we could use multiple groups, but as you said sadly this cannot be achieved.
If there is another way of doing this then i would appreciate some guidance.
Joe
BrianL2
Sep 08, 2015NETGEAR Employee Retired
Hi JoeBishopCDS,
Kind regards,
BrianL
NETGEAR Community
