Nisse67's avatar
Nisse67
WNAP320 Firmware 3.0.0.7Upgrade Failing, can not access WNAP320 via Internet Explorer
Hello.
After upgrad to 3.0.0.7 I can not connect to the AP. I tried both 192.168.0.100 and 192.168.0.236.
  • Hi Nisse87,
    Welcome to the community! :)
    1. What is the behavior of the LED lights of your WNAP320?
    2. Did you perform the firmware upgrade via a wireless connection or wired connection to the WNAP320?
    3. Have you tried to reboot your WNAP320?
    4. Have you tried to factory reset your WNAP320?
    I look forward to your response.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Hi Nisse87,
    DaneA
    • Nisse67's avatar
      Nisse67
      Hello DaneA!
      All LEDs are green and looks normal to me.
      Wired connection.
      Yes, I hav rebooted the device several times
      Yes, I have factory reset also serveral times
      I relay do not know what to do!
      Thanks for your qiuck response.
      Best Regards
      Nisse87
      • DaneA's avatar
        DaneA
        Hi Nisse67,
        Based from your answers, I recommend you to open an online case with NETGEAR Support here because there is a recovery procedure for NETGEAR Access Point/s and our NETGEAR Support team will be able to assist you with it.   However, if the recovery procedure is not applicable nor helpful, then be ready to submit a soft copy of the Proof of Purchase or Sales Invoice of your WNAP320 for warranty verification.  A possible replacement will be processed if your WNAP320 is still within the hardware warranty.
        DaneA
ProSupport for Business
