crx
Oct 07, 2015Initiate
WNDAP360 / WMS5316 - cannot add AP since firmware
Hi we have just updated firmware on 2 of our Aps (WNDAP360) and cannot add them into the WMS5316 (ProSafe 16ap) I have tried carrying out a reset, it locates the device, but the progress indicato...
- Oct 07, 2015
Now resolved
Had to manually assign an IP in same subnet (which had already been done), then reboot the WMS, then try and add again. Connection established and the progress indicator increased. Several times it failed anyway at 40% - 60% and stated Authentication failed. However it did at least change the IP to the new one so something was working.
I left it alone and went back to it and it said connected. It seems the synch just crashes constantly but eventually works itself out. I then changed the password / group, it said failed again and eventually worked itself out.
Garbage
crx
Now resolved
Garbage
