Zdr_IT
Jan 02, 2018Guide
GC728XP Switch nicht in Deutschland zu finden.
Hallo liebe Community, ich möchte gerne den Insight Managed Gigabit Ethernet/10G SFP+ Smart Cloud Switches GC728XP in Deutschland kaufen. Allerdings kann ich den Switch nicht auf der Netgear-DE S...
occamsrazor
Feb 25, 2018Guide
Zdr_IT- Sorry I don't speak German but used Google Translate on your post. As you are one of the few people I can find who actually has one, can you tell us more about how you are liking it? Are you using the cloud portal to manage or the local web interface? How is the fan noise? Any other observation would be most welcome, thanks.
Entschuldigung, ich spreche kein Deutsch, aber verwende Google Translate auf deinem Post. Da du einer der wenigen Leute bist, die ich finde, die einen haben, kannst du uns mehr darüber erzählen, wie es dir gefällt? Verwenden Sie das Cloud-Portal zur Verwaltung oder die lokale Web-Schnittstelle? Wie ist das Lüftergeräusch? Jede andere Beobachtung wäre sehr willkommen, danke.Zdr_IT
Feb 25, 2018Guide
Dear occamsrazor,
my experience is not representative for a general performance review but I let you know what I know so far.
I was using the inside app in the beginning but experienced multiple problems when saving settings (e.g. disabling PoE for certain ports, LAG config). Therefore, I switched to the web based version to set-up the switch. Even in the web based mode there are a few problems but I think this is normal for a new device when you get it that early. I have the switch in my server room, therefore the fan noise is not really an issue. I checked it this morning and I have to say... I can not hear a fan at all. But keep in mind, even though I have multiple cameras, computers, servers, etc. it is still a personal home not a company. If the traffic is different the fan noise might be different.
I think it will take a few firmware updates until everything is fixed but I am okay with that as the devise has an excellent price/performance ratio and that was most important for me. Everything else is only software and I trust that Netgear will fix everything accordingly.
cheers!
Machen Sie mit!
ProSupport for Business
