RickyDan78's avatar
Apr 15, 2023
V1.4.12.2 Not off to a great start.
So V1.4.12.2 was installed on my CAX30 overnight between Thursday 4/13 and Friday 4/14. Immediately we have issues with internet in our house. Phone and tablets have trouble loading pages. When toggle to cell data everything loads just fine. Internet speeds still test good, but at times all devices indicate no internet on the WiFi I am connected to. From my experience with this concern: it appears to have slightly better speeds when it is working however, connectivity is still a problem.
  • FURRYe38's avatar
    Any updates on this?
  • FURRYe38's avatar
    What devices are you speed testing on? Speed testing with NH app or Ooklas installable speed test app?
    Do ethernet connected PC speeds look ok?
    What channels are you using? I'm using 1 and 161 here.
    After v1.4.12.2 was on your CAX30, Had a factory reset and setup from scratch been performed afterwards? A complete pull of the power adapters for a period of time after the factory reset then walk thru the setup wizard and setup from scratch with a wired PC and web browser. Recommend setting the default DHCP IP address pool range to the following after applying and a factory reset: 192.168.#.100 to 192.168.#.200.
    https://kb.netgear.com/24089/How-do-I-specify-the-pool-of-IP-addresses-assigned-by-my-Nighthawk-router
    Im also on v.12.2
    Please post a copy and paste of the modems connection status and event log page.
    https://kb.netgear.com/30007/How-do-I-obtain-the-cable-connection-information-from-a-NETGEAR-cable-modem-modem-router
    https://kb.netgear.com/30008/How-do-I-view-or-clear-the-event-logs-on-my-NETGEAR-cable-modem-or-modem-router
    Neodymium RickyDan78
    • RickyDan78's avatar
      RickyDan78
      Tutor
      Thank you for your response.  Just performed the factory reset again.  Let it come back up, and power cycled for 60 seconds.  Logged back in and performed complete set up from scratch.
      2.4 band is set to channel 1
      5 band is set to channel 161
      (Netgear support and I worked on setting the best channels in my location recently, and we have found these work best here)
      Address pool range has now been set to 100-200.
      After this, wired to port 4 of the router, speeds (Ookla website) are reading 320Mbps down, 20-22Mbps up.
      Below taken with Ookla installed app:
      2.4 - between 74-105Mbps down, 20-22Mbps up.
      5 - between 701-747Mbps down, 20-22Mbps up.
      Before factory reset some apps would not load, Netflix & Discovery+ would not load movies.  Since FR they seem to be working fine  We will continue to monitor this daily.
      Paste of event log:
      TimePriorityDescription
      2023-04-17 16:30:11Critical (3)UCD invalid or channel unusable;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1;
      2023-04-17 16:30:11Notice (6)DS profile assignment change. DS Chan ID: 32; Previous Profile: ; New Profile: 1 2 3.;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1;
      1970-01-01 00:00:33Notice (6)Honoring MDD; IP provisioning mode = IPv6
      1970-01-01 00:00:27Critical (3)UCD invalid or channel unusable;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1;
      1970-01-01 00:00:25Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      2023-04-17 16:26:23Critical (3)UCD invalid or channel unusable;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1;
      2023-04-17 16:26:23Critical (3)SYNC Timing Synchronization failure - Loss of Sync;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1;
      1970-01-01 00:02:45Critical (3)No Ranging Response received - T3 time-out;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1;
      1970-01-01 00:02:42Critical (3)UCD invalid or channel unusable;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:90:f0:36:00:00;CM-QOS=1.1;CM-VER=3.1;
      1970-01-01 00:02:19Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      1970-01-01 00:00:41Critical (3)SYNC Timing Synchronization failure - Failed to acquire QAM/QPSK symbol timing;CM-MAC=6c:cd:d6:81:01:1c;CMTS-MAC=00:00:00:00:00:00;CM-QOS=1.1;CM-VER=3.1;
      Paste of Cable Connection:
      <tabindex=-1>Startup Procedure</tabindex=-1>
      ProcedureStatusComment
      Acquire Downstream Channel447000000 HzLocked
      Connectivity StateOKRegistration Complete
      Boot StateOKOperational
      SecurityEnabledBPI+
      IP Provisioning ModeHonor MDDIPv6 only
      <tabindex=-1>Downstream Bonded Channels</tabindex=-1>
      ChannelLock StatusModulationChannel IDFrequencyPowerSNRCorrectablesUncorrectabables
      1Locked256 QAM4447000000 Hz-4.-5 dBmV44.3 dB00
      2Locked256 QAM1429000000 Hz-4.-5 dBmV44.2 dB00
      3Locked256 QAM2435000000 Hz-4.-5 dBmV44.2 dB00
      4Locked256 QAM3441000000 Hz-4.-8 dBmV44.1 dB00
      5Locked256 QAM5453000000 Hz-4.-4 dBmV44.2 dB00
      6Locked256 QAM6459000000 Hz-4.-4 dBmV44.3 dB00
      7Locked256 QAM7465000000 Hz-4.-4 dBmV44.2 dB00
      8Locked256 QAM8471000000 Hz-4.-5 dBmV44.2 dB00
      9Locked256 QAM9477000000 Hz-4.-6 dBmV44.1 dB00
      10Locked256 QAM10483000000 Hz-4.-5 dBmV44.2 dB00
      11Locked256 QAM11489000000 Hz-4.-8 dBmV43.9 dB00
      12Locked256 QAM12495000000 Hz-4.-5 dBmV44.1 dB00
      13Locked256 QAM13501000000 Hz-4.-6 dBmV44.0 dB00
      14Locked256 QAM14507000000 Hz-4.-9 dBmV43.8 dB00
      15Locked256 QAM15513000000 Hz-4.-4 dBmV44.1 dB00
      16Locked256 QAM16519000000 Hz-4.-8 dBmV43.9 dB00
      17Locked256 QAM17525000000 Hz-5.-4 dBmV43.5 dB00
      18Locked256 QAM18531000000 Hz-5.0 dBmV43.6 dB00
      19Locked256 QAM19537000000 Hz-5.-4 dBmV43.4 dB00
      20Locked256 QAM20543000000 Hz-5.-5 dBmV43.4 dB00
      21Locked256 QAM21549000000 Hz-5.0 dBmV43.7 dB00
      22Locked256 QAM22555000000 Hz-5.-6 dBmV43.2 dB00
      23Locked256 QAM23561000000 Hz-5.-8 dBmV43.0 dB00
      24Locked256 QAM24567000000 Hz-5.-6 dBmV43.2 dB00
      25Locked256 QAM25573000000 Hz-5.-8 dBmV43.0 dB00
      26Locked256 QAM26579000000 Hz-5.-6 dBmV43.2 dB00
      27Locked256 QAM27585000000 Hz-5.-8 dBmV43.0 dB00
      28Locked256 QAM28591000000 Hz-5.-7 dBmV43.1 dB00
      29Locked256 QAM29597000000 Hz-5.-9 dBmV42.9 dB00
      30Locked256 QAM30603000000 Hz-6.-4 dBmV42.5 dB00
      31Locked256 QAM31609000000 Hz-6.0 dBmV42.9 dB00
      32Locked256 QAM32615000000 Hz-6.-5 dBmV42.5 dB00
      <tabindex=-1>Upstream Bonded Channels</tabindex=-1>
      ChannelLock StatusUS Channel TypeChannel IDSymbol RateFrequencyPower
      1LockedATDMA15120 Ksym/sec16400000 Hz51.3 dBmV
      2LockedATDMA25120 Ksym/sec22800000 Hz51.5 dBmV
      3LockedATDMA35120 Ksym/sec29200000 Hz51.3 dBmV
      4LockedATDMA45120 Ksym/sec35600000 Hz51.8 dBmV
      5Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
      6Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
      7Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
      8Not LockedUnknown00 Ksym/sec0 Hz0 dBmV
      <tabindex=-1>Downstream OFDM Channels</tabindex=-1>
      ChannelChannel IDIndicatorSubcarrier Zero FrequencyActive Subcarrier Number RangeTotal CodewordsUncorrectable Codewords
      1193Non-Primary803.6 MHz148 ~ 394764971160
      20Other0 MHz0 ~ 000
      <tabindex=-1>Upstream OFDMA Channels</tabindex=-1>
      ChannelUpstreamIsMutedRanging StatusSubcarrier Zero FrequencyActive Subcarrier Number RangeSymbols Per FrameTx Power
      1 Other0 MHz0 ~ 000 dBmV
      2 Other0 MHz0 ~ 000 dBmV
      • FURRYe38's avatar
        Ok, though power to the modem is with in specs, could check to see if the ISP would raise the power just a bit. Maybe up to -1 to 0db?
        Correctables and un-correctables is zero so thats good.
        Any Criticals seen in the Event logs needs to be reviewed by the ISP. Have NG check these as well. Includes any Warnings or Errors as well if seen here.
        See how it goes and keep us posted.
    • Neodymium's avatar
      Neodymium
      Tutor
      The devices I’ve chiefly done the speed tests are an iPhone 12 Pro Max, Mac mini (M1, 2020), and a MacBook Pro (2016).
      The first two devices are Wi-Fi 6, and the latter Wi-Fi 5. The iPhone and MBP showing similar Wi-Fi speeds (120-170mbps) for both web and app versions from Ookla, but the NH app (on iPhone only) tests at an average of 400mbps. The Mac mini is connected via gigabit ethernet and currently bats a solid 930mbps (Ookla web and app) where it performed slightly better at a solid 970mbps on versions prior to 1.4.11.2.
      I had done a reset back when I had to manually install 11.2, but not for 12.2 yet. I’ll eventually write back with the status and logs as well!
      • FURRYe38's avatar
        Lets try a FR and setup from scratch.
        Be sure to not enable any Armor, SPC or Traffic Meter of the bat.
        I'm seeing this on my iPhone 12 Pro Max with the NH app:
        Was told this was max we'll see thru the NH app. Wired speeds with a ethernet connected PC gets me near my 900Mpbs and to spec 50Mpbs on the up though. I have a RAXE500 in wireless bridge mode connected to the 5Ghz radio on the CAX30. I see to spec speeds thru it as well.
        Please also post the modems connection status and event log page.
  • ChristineT's avatar
    ChristineT
    NETGEAR Employee Retired
    Hello RickyDan78 and Neodymium ,
    Your feedback has been noted and we are looking into this.
    Keep the feedback coming!
    Kind Regards,
    Christine
  • Same here. No connection issues my way, meaning I connect just fine but my speed tests have only been slightly faster than 1.4.11.2 (ie: 120 mbps from about 100 mbps) which is very poor compared to the 500-700+ mbps I experienced before 1.4.11.2 and 1.4.12.2
      RickyDan78
      Tutor
      Yes! Before I would consistently test between 600-800. Since 1.4.11.2 & now 1.4.12.2 I am testing around 160-200 max. Definitely frustrating.
