LightlyToasted's avatar
Apr 21, 2026
GC108PP managed switch: how to change management VLAN?
System -> Management -> IP Configuration has a text box for "Management VLAN ID". I have VLANs configured on this switch. When I try to set the value to anything other than the default of "1", I get ...
  • LightlyToasted's avatar
    Apr 21, 2026
    Before defining the Management VLAN ID, the VLAN must exist on the switch.
    The desired management VLAN does exist on the switch and I have verified that it works.
    To avoid the management access isn't lost in space (mind you there is no external serial console on these smart switches): At least define a port as an access port for the VLAN ID desired, or as a port of a trunk carrying the VLAN intended, from where you are managing or operating the network.
    I had a trunk port containing the desired management VLAN, and an access port where the management VLAN was tagged.  That was not sufficient.  I then gave one port a PVID of the desired management VLAN, and that worked - I could set the management VLAN on the web interface (Insight is not applicable).
    I think this is either a bug or a documentation bug.  Nowhere does it state that you must have a port with PVID = management VLAN in order to set the management VLAN.
    Thanks for your help and the insight to allow me to fix my problem.
ProSupport for Business
