phongshader
Dec 15, 2018Tutor
No attached wired devices
I just installed a GC110P switch so that I could manage IP cameras remotely, however after I got everything up and running the switch was not showing any attached devices. There are two IP cameras at...
- Dec 18, 2018
If the device you connect does not support LLDP that's all you get, nit much one can do. Few embedded systems have a control to enable to the LLDP is done as part of the Ethernet link establishment.
schumaku
Dec 16, 2018Guru - Experienced User
Insight -> Clients does list only wireless clients associated (and temporarily disconnected) with the Insight wireless access points.
Go to the switch device level (double click), and check Attached Devices. Information showing up here is based on Link Layer Discovery Protocol (LLDP) only.
phongshader
Dec 16, 2018Tutor
There should be 3 ports utilized, 1 is an uplink to the router, 2 is an IP camera, 3 is an IP camera but here's what I got:
- schumakuDec 16, 2018Guru - Experienced User
Can't see the screenshots yet - however I assume you try to tell us that there is no IP, MAC, or VLAN information shown. As mentioned, this data is derived from the neighbor device by LLDP. If not available, nothing will be shown.
- phongshaderDec 17, 2018Tutor
I don't understand how LLDP works even after reading through the wiki page. It sounds like, if I'm understanding , the identity/settings of a port are reported by the neighboring port or device..."used by network devices for advertising their identity, capabilities, and neighbors on an IEEE 802 local area network"? If that's the case how would I go about getting two ports with a device on each port to be self aware or see it's neighbor, or is another device needed, such as a router, to fulfill the need for a neighboring device? How do I get the ports to be able to broadcast what is attached to it or if it's in use?
- schumakuDec 18, 2018Guru - Experienced User
