phongshader's avatar
Dec 15, 2018
No attached wired devices
I just installed a GC110P switch so that I could manage IP cameras remotely, however after I got everything up and running the switch was not showing any attached devices. There are two IP cameras at...
  • schumaku's avatar
    schumaku
    Dec 18, 2018
    If the device you connect does not support LLDP that's all you get, nit much one can do. Few embedded systems have a control to enable to the LLDP is done as part of the Ethernet link establishment.
ProSupport for Business
