LightlyToasted
Apr 21, 2026Guide
GC108PP managed switch: how to change management VLAN?
System -> Management -> IP Configuration has a text box for "Management VLAN ID". I have VLANs configured on this switch. When I try to set the value to anything other than the default of "1", I get ...
- Apr 21, 2026
Before defining the Management VLAN ID, the VLAN must exist on the switch.
The desired management VLAN does exist on the switch and I have verified that it works.
To avoid the management access isn't lost in space (mind you there is no external serial console on these smart switches): At least define a port as an access port for the VLAN ID desired, or as a port of a trunk carrying the VLAN intended, from where you are managing or operating the network.
I had a trunk port containing the desired management VLAN, and an access port where the management VLAN was tagged. That was not sufficient. I then gave one port a PVID of the desired management VLAN, and that worked - I could set the management VLAN on the web interface (Insight is not applicable).
I think this is either a bug or a documentation bug. Nowhere does it state that you must have a port with PVID = management VLAN in order to set the management VLAN.
Thanks for your help and the insight to allow me to fix my problem.
Khidhishka
Oct 12, 2026Aspirant
Is this also the case for a GS108Tv3?
Is it good practice to configure a trunk with PVID=management VLAN? All other ports need another VLAN ID untagged so I cannot change PVID there.
schumaku
Oct 12, 2026Guru - Experienced User
Khidhishka wrote:Is this also the case for a GS108Tv3?
Shouldn't be required. Give it a try and configure the GS108Tv3 Management VLAN to a VLAN different from the VLAN ID 1....
Khidhishka wrote:Is it good practice to configure a trunk with PVID=management VLAN?
What's the idea here - having a port (the trunk port) ready to connect a PC without a VLAN config as a local management station? This would also require the same port to be configured for that management VLAN as untagged.
in the example on this thread, it appears to be a workaround to avoid an error popping up. Not something I"d expect from a random Netgear Smart Managed Switch.
