schumaku
Oct 17, 2018Guru - Experienced User
BR500 - Firewall Rules for Internet/WAN -> Router and Internet/WAN -> Port Forwarding -> LAN?
Reading the BR500 documentations up and down - even on the n-th attempt late night I can't find if the new Insight Router has controls (strongly required nowadays) the ability to configure IPv4 and IPv6 Firewall Rules for Internet/WAN -> Router and Internet/WAN -> Port Forwarding -> LAN.
Looks like Netgear does try again to forward what is missing (for I don't know how long) on the standalone managed consumer Nighthawk, Orbi, or business Orbi Pro, and WAC510 routers. Curious when Netgear does arrive in the 21st century of simple small business and SOHO routers. That's what all Insight managed devices are supposed to be johngm, isn't it?
- YeZNETGEAR Expert
The initial Insight support for BR500 focuses on VPN setup and VLAN setup, your message is well taken, we plan to support firewall configuration in future version.
Thank you!
Hello YeZ,
During today BR500 Webinar presentation it was mentioned that this feature should exist already, but has not made it into the documentation. What is correct now? A configurable firewall is a core feature for a very basic SOHO or small business router. We might be fine with a local Web management while Insight mode is on. Many other things are optional - like IDS, deep packet inspection, policy enforcements, ... And if you think that I'm picky - yes, the VPN feature (as nice as it looks) has gained far to much momentum in the marketing of this product.
I hope you understand that when I'm talking of firewall rules I expect an object oriented platform, where IP addresses, IP address groups, port sets, sets of multiple IP subnets, and much more are objects - so we have to change things just once, and not in many different locations (error prone) like NAT port forwarding and firewall rules where e.g. the set of ports must be the same.
Sory for digging again - I'm confused now. Insight Instant VPN Routers says:
"Full Business protection with integrated firewall
The Insight Instant VPN Router also adds a layer of protection with the inclusion of a firewall. The firewall prevents any unauthorized access to the network and will monitor the communications between the business network and the outside world according to internal rules. It will also warn of any malicious connection attempt. The Firewall rules can easily be set up in the Insight app or Cloud Portal to get you started intantly."
Ref. the malicious connection I don't say a word.
