chascent's avatar
chascent
Luminary
Feb 11, 2016
R8500 Constant WAN Internet disconnects/connects!
    My wireless is rock solid, never disconnects. The WAN is another problem, see below from log:
[Internet disconnected] Thursday, Feb 11,2016 02:35:35
[Internet connected] IP address: 192.168.100.11, Thursday, Feb 11,2016 02:35:18
[Internet disconnected] Thursday, Feb 11,2016 02:35:16
[Time synchronized with NTP server] Thursday, Feb 11,2016 02:29:55
[Internet connected] IP address:  Feb 11,2016 02:29:55
[Internet disconnected] Thursday, Feb 11,2016 02:29:51
[Internet connected] IP address: , Thursday, Feb 11,2016 02:29:35
[Internet disconnected] Thursday, Feb 11,2016 02:29:33
[Time synchronized with NTP server] Thursday, Feb 11,2016 02:13:51
[Internet connected] IP address: , Thursday, Feb 11,2016 02:13:51
[Internet disconnected] Thursday, Feb 11,2016 02:13:47
[Internet connected] IP address:  Thursday, Feb 11,2016 02:13:31
[Internet disconnected] Thursday, Feb 11,2016 02:13:29
[DHCP IP: (xxx.xxx.x.x] to MAC address  Thursday, Feb 11,2016 01:31:16
[Time synchronized with NTP server] Thursday, Feb 11,2016 00:55:34
[Internet connected] IP address:Thursday, Feb 11,2016 00:55:34
[Internet disconnected] Thursday, Feb 11,2016 00:55:30
[Internet connected] IP address:  Thursday, Feb 11,2016 00:55:13
[Internet disconnected] Thursday, Feb 11,2016 00:55:11
   I am also noticing numerous Time Syncs. On firmware R8500-V1.0.2.28_1.0.42.
QOS ON
Band Steering ON
14 static ip's
Anyone have any insight?
CC
  • Same problem here (I started the thread) WAN disconnects.
    Cable company came out and tested and replaced the Modem.
    2 Hours later I had a WAN disconnect. RMA # 2 will be here today.
    I never had this problem with the R7000!
    CC
  • Having a similar issue, although I lose both Wired and Wireless access. Sometimes the router successfully reconnects while in other instances, I have to reboot. I recently applied firmware V1.0.2.28_1.0.42 with hopes some of these issues would encounter more elapsed time between disconnects - no success. I have confirmed my cable modem is not the issue by working with my ISP during the disconnects. I am running QOS and UPnP.
    [Internet connected] IP address: , Thursday, Feb 11,2016 05:44:36
    [Internet disconnected] Thursday, Feb 11,2016 05:44:36
    Appreciate any suggestions.
    • ElaineM's avatar
      ElaineM
      NETGEAR Employee Retired
      Can you guys try to lower down your MTUs?
      See this link.
      • chascent's avatar
        chascent
        Luminary
        OK just set mine from 1500 to 1472. Will report back.
        CC
  • Just upgraded to the R8500 from the R7000.
    Seemed to be working fine last night, during setup, it prompted me to update the firmware (which I did) to V1.0.2.26_1.0.41
    All day today, I've been having constant cutouts of internet connectivity.  I think it may be an issue with my cable modem, as it looks like it is in the middle of rebooting everytime I lose connectivity but, is it in anyway possible that the router is causing this?  Perhaps some kind of feedback to the modem?
    • ElaineM's avatar
      ElaineM
      Bypass the router by directly connecting your pc to the modem and see if you'll experience drop outs.
      After firmware update, I suggest that you factory reset the unit then reconfigure.
      • mikegoldnj's avatar
        mikegoldnj
        Did that when I was on call with cable company.  Seemed like the modem was still power cycling.
        I suspect it's either the modem or signal issues with the cable company because, even when the internet connection drops, I still have WiFi connection to the router.
