Bob_Bamburg's avatar
Apr 23, 2019
Error Communicating with Device
I was setting up the switch, creating a vlan on port 3, and lost contact with the device.
   Could not access it via Web or Cloud interface.
After reading some posts in this forum, I removed the device from the Cloud account and using a paperclip factory reset the switch.
  The Web interface came back and I can log in using the default password.
Then I claimed the switch back into the Cloud Management and lost all contact again.  Both Web and Cloud.
I let it sit overnight hoping it would complete the cloud configuration but no luck.
Removed it from the account again, factory reset it and access is back.
Added it back to the cloud account and lost access again.
Where do I go from here?
  • Update....
    Deleted the switch from the cloud and factory reset it.
    While adding the device, created a new network {Net2}.     Cloud and web access continued to work after 20 min.
    Added the switch back to the original network. {Net1} The Insight App shows “Configuration in process”.  The cloud Light on the switch is Off.  Received a message that the device is offline.  App changed to “Device is Disconnected”.
    Deleted the switch from the cloud and factory reset it. AGAIN
    Added the device back to Net2.  It attached to the cloud configuration for Net2 and continued 2-way communications.   The cloud light is Blue
    It just doesn’t work when reconnecting to the Net1 account.
    Any Ideas???
  • MrJoshW's avatar
    MrJoshW
    NETGEAR Employee Retired
    Bob,
    Any configuration still saved to Insight will be pushed to the device once the device comes back up. If you can, in Insight, create a new location and only add the switch to the location and verify if the switch is able to come up and not disconnect from Insight.
    If this works, verify in your original location if there are any changes made to the vlan that is causing a communication conflict with the switch when it is being added.
    • Bob_Bamburg's avatar
      Bob_Bamburg
      Guide
      MrJoshW, When the device was reset and put into a different LAN it did work corectly.
          I am sure the problem is a VLAN that was setup on the device but the question is, how to take that VLAN back off of the configuration?
      When I access the "VLans in Use" in the Cloud Portal, it shows "Device Monitoring info not found."
       How does one remove the VLAN configuration from that profile?
      • MrJoshW's avatar
        MrJoshW
        Hello,
        Is the device showing online in Insight? What does the cloud LED on the front of the switch show? If the device is reporting offline, you can manage it locally by logging into the switch's local GUI and seeing what VLANS are being monitored as well as verifying if the device is being managed through Insight or local management under the switch's summary screen.
ProSupport for Business
