Xetra
Aug 20, 2022Aspirant
impossible purchase insight service
Hello I can't purchase insight service. I can't select the duration and the number of Aps.. All service Insight have the same problem. Is some one can help me Thanks
Xetra
It's the same with IOS app, Chrome, and IE.
Thanks
DaneA
Aug 21, 2022NETGEAR Employee Retired
From the image you have posted, it seems you that want to purchase Captive Portal Credits. Were you able to purchase Captive Portal Credits before? Also, on what NETGEAR device are you going to use the Captive Portal Credits?
DaneA
NETGEAR Community Team
- XetraAug 22, 2022Aspirant
sorry it was the wrong screenshot, but it's the same problem with all insight services
- DaneAAug 23, 2022NETGEAR Employee Retired
Have you tried accessing the Insight Portal using Incognito mode in Chrome or trying other browsers then check if you can make a purchase? If ever it will still not work, I suggest you to open a support ticket with NETGEAR Support here at anytime here for further investigation.
DaneA
