Pristle
Jan 13, 2020Aspirant
Insight Cloud Portal - GC110 - Connected Neighbors
Hi,
Re: Netgear Insight GC110 (Firmware 1.0.5.25)
Am a at a bit of a loss here. I picked up a pair of these switches for a small site, who are hoping to better manage their internet traffic. I have also signed onto the Premium subscription for "mobile app + cloud".
My question is: Where can I edit the name of the connected devices? Other than MAC addresses, the fields are blank under 'Summary'. Inutitively I headed for 'Settings', but that presents a blank screen (regardless of browser).
I then thought perhaps if I use the 'Direct Connect Web-browser', I may have better fortune. Nada, the interface must be among the worst I've seen in a long time.
Is there a CLI type interface on these devices? It seems counterintuitive when the hype for these is 'cloud'.
Any guidance would be appreciated.
Paul
There seems to be some confusion. The information under Device -> Switch -> [Click on the port] -> Connected Neighbors -> Status -> Neighbor Info is dynamically updated according the device plugged, it's provided by LLDP-MD. None of these fields is intended to be edited for the obvious reason. When you go the Device -> Switch -> [Click on the port] -> Settings you find the Port Description field, which is editable. Unfortunately, this information (and some more ineresting one) is not used elsewhere (e.g. on Devices -> Switch on the Port mouse-over or the Port information below.
- PristleAspirant
Hi,
Thank you for your response, not that it was particularly helpful.
Your comment "None of these fields is intended to be edited for the obvious reason" doesn't really elaborate on the 'obvious reason'.
It would seem my site is not populating properly, with only the Netgear and Ubiquiti devices showing up. Of the 15 other available ports, despite all clients being LLDP enable, only 4 are offering up their MAC addresses. None of the ports have 'Neighbor Name' nor 'Neighbor Description' populated.
Even the one port which I have configured with a 'Neighbor Description' via the mobile app, doesn't propogate to the PC based cloud portal.
A very clunky piece of work to say the least.
Paul
Pristle wrote:Your comment "None of these fields is intended to be edited for the obvious reason" doesn't really elaborate on the 'obvious reason'.
All the information shown under Neigbour Info, including the Neigbour Description (App says just Description) is coming from the connected device by LLDP - and can't be edited. That's why it's obvious.
Pristle wrote:It would seem my site is not populating properly, with only the Netgear and Ubiquiti devices showing up. Of the 15 other available ports, despite all clients being LLDP enable, only 4 are offering up their MAC addresses. None of the ports have 'Neighbor Name' nor 'Neighbor Description' populated.
What are these other clients, what kind of lldpd is in place there?
Please note that a common Windows 10 client - with the Microsoft-LLDP-Driver enabled on the interface - does only provide Chassis ID: [MAC], Chassis ID Subtype: MAC Address, Port ID: [MAC], Port ID Subtype: MAC Address - neither a neighbor name or description.
Pristle wrote:Even the one port which I have configured with a 'Neighbor Description' via the mobile app, doesn't propogate to the PC based cloud portal.
Provide more information - "Neighbor Description" isn't editable or configureable. You might talk of the confusing "Port Description" label for two purposes:
a) the Port Description, an editable string on on the switch port (which deploys nicely to both the App as well as the Web UI for me), andb) the Port Description, in the Neigbor Information, LLDP based, showing the connected device port information, e.g. "Device Port 5" from the connected device.
