testuser777
Jun 26, 2026Aspirant
Insight Pro License
My company has purchased an Insight Pro license as we needed it to upload some NetGear Nighthawk devices to insight. The biggest issue I am having is where I need to go to upload it. I was directed t...
schumaku
Jun 27, 2026Guru - Experienced User
Review the email you had received with the license key please.
Instructions
For Existing Insight Pro Users:
Simply follow the steps below to add your license:
Step 1: Go to insight.netgear.com/#/register and log in using your credentials.
Step 2: Click on Account Management in the top-right corner of the page.
Step 3: From the left-hand menu, select Subscriptions.
Step 4: Click the Add Purchase Confirmation Key button to enter your new license.
For New Users or Existing Premium Users:
Follow the steps below to create a new Insight Pro account or upgrade from a Premium account :
Step 1: Go to insight.netgear.com/#/register.
Step 2: Enter your email address and click Next.
There is no way to mix and merge Insight Premium with Insight Pro.
testuser777 wrote:purchased an Insight Pro license as we needed it to upload some NetGear Nighthawk devices to insight.
What Netgear Nighthawk devices (type like Access Point, Switch ..) and model please.
To my knowledge, there are not many Netgear Nighthawk devices supporting Netgear Insight, the only exception are certain supported Nighthawk 4G/5G mobile routers.
Anyway, the license for Insight Pro can only be registered to an existing Insight Pro account.
testuser777
Jul 06, 2026Aspirant
Some of the models include the Nighthawk M6 MR6110 and Nighthawk M6 MR6500.
- schumakuAug 30, 2026Guru - Experienced User
On the Insight Web UI (or for the sake on the App), under
https://insight.netgear.com/locationDevice (which requires to be configured of course), user the [Add] button.
In a subsequent pop-up, you have to enter the device serial number.
