jsroman
Jun 07, 2021Aspirant
Insight Toplogy not visible in abstract view.
Tree view and ssid view work as intended under Toplogy Views on Insight Portal but when switching to Abstact view nothing is visible. Any suggestion on how to correct. A wac540 and a wax610 are APs a...
- Retired_MemberJun 14, 2021
Hi,
We have released newer version of IM6.2.
Could you please try viewing "Abstract View" of the topology now?
Please let us know.
Thanks,
Sudheer
Retired_Member
Jun 07, 2021Hi,
We have fixed this issue in IM6.1MR version.
Could you please provide Insight credentials to debug further?
Thanks,
Sudheer
Retired_Member
Jun 08, 2021Hi,
You can give technical support access or provide your credentials by sending email: [email protected].
Thanks,
Sudheer
