CBS-jbcbussoft
Nov 13, 2018Guide
Insight VPN connection to BR500 questions
I am trying to setup a Client to Gateway connection. I have the BR500 configured to use DDNS. I have setup a VPN group, sent an invitation, installed software on my computer, and connected the Insigh...
- Nov 21, 2018
I just got an email asking me if I had a solution to my issue. I do but it did not come from the forum. I had already performed all of the steps required to create the tunnel before I posted my question per my original post. Not finding a solution here I contacted support and was able to get the tunnel up and running. I posted this info to this thread as well. How do I close this thread?
schumaku
Nov 13, 2018Guru - Experienced User
Assuming computer is a Windows system - have renamed the network connection as per the fine manual p.130 ff.?
- CBS-jbcbussoftNov 13, 2018Guide
These are OpenVPN instructions. I wasn't using OpenVPN.
- schumakuNov 13, 2018Guru - Experienced User
Afraid, not aware on how to configure and/or check the Instant VPN clients on Windows or MacOS. No documentation, no downlods available - YeZ, seriously???)
Just for curiosity, there aren't the same TCP/IP subnets on both ends of the Instant VPN.
No the remote pc has a 192.168.3 address and the router has a 10.0.0 address. The User Manual says this is possible with Insight. I guess I will have to contact support.
