CBS-jbcbussoft
Nov 13, 2018Guide
Insight VPN connection to BR500 questions
I am trying to setup a Client to Gateway connection. I have the BR500 configured to use DDNS. I have setup a VPN group, sent an invitation, installed software on my computer, and connected the Insigh...
- Nov 21, 2018
I just got an email asking me if I had a solution to my issue. I do but it did not come from the forum. I had already performed all of the steps required to create the tunnel before I posted my question per my original post. Not finding a solution here I contacted support and was able to get the tunnel up and running. I posted this info to this thread as well. How do I close this thread?
schumaku
Nov 14, 2018Guru - Experienced User
c3po YeZ Does the BR500 still not have an embedded DNS server for automatic registration of the local subnet based on the hostname provided by BOOTP/DHCP (e.g. by default for a .local or a custom domain), and then some ways to manage the local DNS manually (and then allow some individual management)?
That's what I would see as real added value.
CBS-jbcbussoft
Nov 14, 2018Guide
I tried my connection again this morning and it did not work. The connection to the router using the Insight app worked but I could go no farther. I did not try to ping at that point. What I had tried was to open an Explorer window and tried browsing to the ip address of a pc behind the router but it would not connect. I also tried Remote Desktop again and I got the Windows you can't connect message. I had received an email from support and per their suggestion I tried chat again and after uploading the screen shots that were requested one of the first questions was can you ping. I had not tried and said so (that made me feel stupid). I pinged the router and the pc behind the router. Then I tried a net view and the rest all just worked. I remember something from one of the first VPNs I setup and there was the issue of keeping the connection alive for the next day and a suggestion was made to use ping to wake up the connection. I do not know why it wouldn't work and I don't know why it started, it just did.
- CBS-jbcbussoftNov 14, 2018Guide
By the way to be able to use Insight for the VPN connection instead of OpenVPN you need the pro/premium version of Insight.
- c3poNov 16, 2018NETGEAR Expert
Hi CBS, Would you please let me know the Cloud/VPN LED status? In normal case, Blue cloud LED and green VPN LED should staty on.
Below are steps to set up Insight VPN:
1. Assign BR500 to a location, currently we only support one BR500 per location. Do so for all your BR500.
2. Create a VPN group.
3. Add one or more BR500 to the VPN group. Currently, VPN group can have 1, 2 or 3 BR500, all other numbers are not supported. All BR500 in the group is fully meshed, meaning their LAN can access each other.
4. Invite VPN users to join the group, they will receive emails to acknowledge joining the group, along with VPN client program download links. Admin can invite 10 clients per BR500 to join the group, for example, if the group has 3 BR500, then admin can invite up to 30 clients to join the group.
5. VPN user lanuch client software, login using NETGEAR SSO account, user will then be presented all groups available to them and select which one to join. Once VPN connecteion is established, the client will be able to access all BR500 subnets which is also listed in VPN client software.
- CBS-jbcbussoftNov 16, 2018GuideMy VPN is up and running.
