KGA20's avatar
KGA20
Insight widgets Usage clients and usage traffic show incomplete graphics
Hi community,
I want to report a bug that affects widgets titled "Usage:Clients" and "Usage:Traffic".
Graphics are not complete. As you can see on the following screenshot, the graphics are cutted on the top.
Same error if you apply a filter.
Cause is that left bar does not show the maximum value
    • KGA20's avatar
      KGA20
      Thanks schumaku for your reply.
      My versions are:
      Web Portal Version : 6.3.26.7
      Cloud Version : 6.3.26.8
      do you have the same?
      • schumaku's avatar
        schumaku
        Difficult to have something different - it's a production system:
        NETGEAR Insight Pro
        Of course there can be certain flaws... YeZ any ieas what can go wrong there?
ProSupport for Business
