User_Zero
Mar 10, 2021Aspirant
NMS300 HTTPS?
Hey all!
I just installed the NMS300 software, i see that it runs on HTTP, using port 8080 by default.
I poked aroudn the config, UG, and KB, but couldn't find this info (maybe my search game is off, today):
Where in the configuration can i change the management port after install?
How do i enable HTTPS management?
Thank you in advance,
Z
- JohnC_VNETGEAR Employee Retired
Welcome to our community! :)
I would like to confirm that you wanted to change the default port 8080 for accessing the NMS300, Is that correct? Do you also want to enable the HTTPS management of the NMS300?
John
NETGEAR Community Team
- User_ZeroAspirant
- techservSWTPAspirant
I would also like to enable HTTPS access to our NMS300, for us (Win10 installation) I did not see the solution in this thread?
Will this also fix the issue of the NMS being able to manage small HTTPS enabled switches such as the GS110V3? Currently it will not log into them even though we have updated the https protocol login credentials.
Thank you!
