4uba's avatar
4uba
NMS300 HTTPS config
Hi Community,
I'm trying to reconfigure Tomcat that comes with NMS300 installation package to access via HTTPS, but I could not success.
Is here anybody who done it successfully already?
Please share you experience!
Thanks
Igor
  • After few hours of fighing with Tomcat 6, I have finally found the solution.
    Mostly I used this article: https://tomcat.apache.org/tomcat-6.0-doc/ssl-howto.html
    But specificly to me steps of config:
    1. CMD >> c:\Program Files (x86)\Java\jre1.8.0_151\bin>keytool.exe -genkey -alias tomcat -keyalg RSA -keystore "c:\tomcatkeystore"
    2. Changes in server.xml ("C:\Program Files\NMS300\NMS300\apache-tomcat-6.0.33\conf\server.xml"):
    <Connector port="8080" protocol="HTTP/1.1"
    connectionTimeout="20000"
    redirectPort="8443" />
    <Connector
    protocol="org.apache.coyote.http11.Http11NioProtocol"
    port="8443" maxThreads="200"
    scheme="https" secure="true" SSLEnabled="true"
    keystoreFile="c:/tomcatkeystore" keystorePass="changeit"
    clientAuth="false" sslProtocol="TLS"/>
    3. Restart tomcat using cli:
    CMD >> c:\Program Files\NMS300\NMS300>StopService.bat
    CMD >> c:\Program Files\NMS300\NMS300>StartService.bat
    That's probably all that you should configure.
    P.S. CMD using Admin access
    Thanks a lot.
    Have a nice day!
    <Connector
    Thanks a lot.
    Have a nice day!
    • JohnC_V's avatar
      JohnC_V
      NETGEAR Employee Retired
      Hi 4uba,
      Thank you for sharing the solution here in our community! The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
      • 4uba's avatar
        4uba
        I got another problem. This problem with CA certificate.
        In previous posts I made simple generation of CA certificate, but now during connection I got this issue:
        So I'm looking for solution to add existed netgear certificate into my keystore. If I find it - I will share solution.
ProSupport for Business
