4uba
Jan 09, 2018Aspirant
NMS300 HTTPS config
Hi Community, I'm trying to reconfigure Tomcat that comes with NMS300 installation package to access via HTTPS, but I could not success. Is here anybody who done it successfully already? Ple...
- Jan 10, 2018
After few hours of fighing with Tomcat 6, I have finally found the solution.
Mostly I used this article: https://tomcat.apache.org/tomcat-6.0-doc/ssl-howto.html
But specificly to me steps of config:
1. CMD >> c:\Program Files (x86)\Java\jre1.8.0_151\bin>keytool.exe -genkey -alias tomcat -keyalg RSA -keystore "c:\tomcatkeystore"
2. Changes in server.xml ("C:\Program Files\NMS300\NMS300\apache-tomcat-6.0.33\conf\server.xml"):
<Connector port="8080" protocol="HTTP/1.1"
connectionTimeout="20000"
redirectPort="8443" /><Connector
protocol="org.apache.coyote.http11.Http11NioProtocol"
port="8443" maxThreads="200"
scheme="https" secure="true" SSLEnabled="true"
keystoreFile="c:/tomcatkeystore" keystorePass="changeit"
clientAuth="false" sslProtocol="TLS"/>3. Restart tomcat using cli:
CMD >> c:\Program Files\NMS300\NMS300>StopService.bat
CMD >> c:\Program Files\NMS300\NMS300>StartService.bat
That's probably all that you should configure.
P.S. CMD using Admin access
Thanks a lot.
Have a nice day!
JohnC_V
Jan 10, 2018NETGEAR Employee Retired
Hi 4uba,
Thank you for sharing the solution here in our community! The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
4uba
Jan 17, 2018Aspirant
I got another problem. This problem with CA certificate.
In previous posts I made simple generation of CA certificate, but now during connection I got this issue:
So I'm looking for solution to add existed netgear certificate into my keystore. If I find it - I will share solution.
